vlan-group synchronization - Cat 6500
Answered Question
Oct 20th, 2008
How can I achieve synchronization of the Cat 6500 vlan-group definitions. VTP domain only updates the 'sh vlans'
yet, the 'show firewall vlan-group' does not display the assigned vlans.
Correct Answer by Jon Marshall about 8 years 6 months ago
Unfortunately you can't, you just have to manually assign them on each switch. It is a pain especially as if the 2 switches have inconsistent vlan-group definitions this can break FWSM failover.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 10/20/2008 - 02:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
new_networker Mon, 10/20/2008 - 02:50
After configuring failover on FWSM, the hostname on the secondary unit gets overwritten. Can this be avoided. I would like to identify via the hostname that which one is active.
Regards.
Syed Iftekhar Ahmed Mon, 10/20/2008 - 10:02
  • Blue, 1500 points or more
Use Prompt command on primary to recongnize which one is active.
prompt hostname context state
Will add sate (primary/secondary) to the prompt.
Your prompt will show you if you are working on an Active or Standby FWSM
Syed Iftekhar Ahmed
