ACE Configuration Synchronization failure
Answered Question
Oct 20th, 2008
I have defined the FT group on ACE, but i don't see configuration getting update on the other module.
The response for 'sh ft peer detail' is as follows
Peer Id : 1
State : FSM_PEER_STATE_DOWN
Maintenance mode : MAINT_MODE_OFF
FT Vlan : 200
My IP Addr : 1.1.1.1
Peer IP Addr : 1.1.1.2
Query Vlan : Not Configured
Peer Query IP Addr : 0.0.0.0
Heartbeat Interval : 200
Heartbeat Count : 20
Tx Packets : 0
Tx Bytes : 0
Rx Packets : 0
Rx Bytes : 0
Rx Error Bytes : 0
Tx Keepalive Packets : 0
Rx Keepalive Packets : 0
TL_CLOSE count : 0
FT_VLAN_DOWN count : 0
PEER_DOWN count : 1
SRG Compatibility : INIT
License Compatibility : INIT
FT Groups : 1
Please assist.
Correct Answer by dario.didio about 8 years 8 months ago
Can you please paste you configuration.
Did you configure both modules with the FT configuration?
Is the FT vlan available on both chassis?
Is the FT vlan trunked between the two chassis?
Overall Rating: 5 (1 ratings)
Correct Answer
dario.didio Mon, 10/20/2008 - 04:25
  • Silver, 250 points or more
new_networker Mon, 10/20/2008 - 04:40
Your first question was the answer. VLAN was missing on the second chassis.
Thanks.
