Cisco 7985 troubles
Oct 20th, 2008
Cisco 7985 IP phone unregisters after some period of time. When I plug it out and in again, it registers with the Call Manager, but becomes unavailable in 5-10 minutes. I have to unplug it and plug it in again to make it work. Other phones work fine.
Can it be just a communication problem somewhere in the wires?
fgasimzade Mon, 10/20/2008 - 03:54
This is what I found in RTMT for this phone:
What are the reasons behind these logs?
kvsaheednetpro Mon, 10/20/2008 - 05:55
Are you using DHCP to reg the phone?
Are you registering IP phone over the wan?
Which version of CM are you using?
Plz reply
fgasimzade Mon, 10/20/2008 - 07:24
Yes, the phone registers over VPN site-to-site connection. Default gateway ping statistic is ok, no packet loss at all. Not sure about DHCP, probably yes.
CM version
