ATA reboot
Oct 20th, 2008
I have the cisco call manager version 6 and the ATA reboot once a week. Why is this happening?
Overall Rating: 5 (2 ratings)
tim.giles Mon, 10/20/2008 - 05:16
Can you tell me what firmware the ATA is using?
There is possibly a problem in firmware prior to version 3.
There is also a known bug which may be relevant?:
CSCso94320 Bug Details
TFTP procedure causes ATA reboot
Symptom:
ATA does an unexpected reboot, and see infinite tftp request at preserv log
Conditions:
ATA enables both channel, but CCM disables auto register and only config one channel.
Workaround:
Disable the second channel to stop infinite tftp request
Is there any more information in the CCM trace files (get them from RTMT - Real-Time Monitoring Tool)
Please rate useful posts...
rob.huffman Tue, 11/11/2008 - 08:34
Hi Somsak,
Here is the process;
Note By default, both Cisco ATA FXS ports are enabled for Cisco CallManager registration. If you do not want to add the Phone 2 FXS port to Cisco CallManager, you must change the Cisco ATA EPID1orSID1 parameter value to 0 to disable the Phone 2 port. (To disable the Phone 1 port, you must change the EPID0orSID0 parameter value to 0.)
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/2_15_ms/english/administration/guide/sccp/sccpach4.html#wpxref70796
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/2_15_ms/english/administration/guide/sccp/sccpaape.html#wp1020682
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/2_15_ms/english/administration/guide/sccp/sccpaape.html#wpxref65796
Hope this helps!
Rob
