ASA Mutiple NAT
Oct 20th, 2008
Hi everybody i have simple situation,
i have a LAN and its connected to ASA and i have a PAT to the lan , so every one in the LAN is going out with the interface IP.
the problem that i have Mail server in MY LAN )same IP range , and i want it to go out with different public ip address
Overall Rating: 3 (1 ratings)
ray_stone Mon, 10/20/2008 - 06:31
In your case, just use static map entry of your Mail Server local IP with Public IP and make access-list for incoming public IP traffic for using mail services.
Ray
motasemkhater Mon, 10/20/2008 - 06:44
i have
static(inside,outside) public ip private ip
this will redirect the traffic that came to public ip to my server ,
what i need that my server to go out with the public ip ..
i think i will need GLOBAL and NAT command ??
suschoud Mon, 10/20/2008 - 06:48
  • Gold, 750 points or more
If you want only your server to xlate to public ip,that is already done through the static command you have.
Go to " whatismyip.com " on the server and you would see the public ip address used in static.
If you have some more computers on inside which need to access internet ( you need to xlate them into public ip ),add :
nat (inside) 1 0 0
global (outside) 1 interface
Do rate if helpful.
Sushil
motasemkhater Mon, 10/20/2008 - 10:18
i already have
nat (inside) 1 0 0
and all inside PC's and servers including my mail server are going out with the interface public IP ,
i want the mail server (which have an ip address from inside network) to go out with different public IP i determine
