FWSM hostname on redundant unit
Answered Question
Oct 20th, 2008
After configuring failover on FWSM, the hostname on the secondary unit gets overwritten. Can this be avoided. I would like to identify via the hostname that which one is active.
Regards.
Correct Answer by Syed Iftekhar Ahmed about 8 years 5 months ago
The code you are running A1(6.3a) doesnt support this command.
Syed Iftekhar Ahmed
Overall Rating: 5 (2 ratings)
Syed Iftekhar Ahmed Mon, 10/20/2008 - 10:01
  • Blue, 1500 points or more
Use Prompt command on primary to recongnize which one is active.
prompt hostname context state
Will add sate (primary/secondary) to the prompt.
Your prompt will show you if you are working on an Active or Standby FWSM
Syed Iftekhar Ahmed
Correct Answer
Syed Iftekhar Ahmed Mon, 10/20/2008 - 10:32
Syed Iftekhar Ahmed
