Change of ACE peer hostname
Answered Question
Oct 20th, 2008
I found the following entry in ACE administration guide but it doesn't work
peer hostname xxxxx
This is to set the secondary units' hostname.
Correct Answer by Syed Iftekhar Ahmed about 8 years 6 months ago
Yes with "no peer hostname" command support on code 1.63 you need to put the hostname on standby before FT configuration.
Syed
The code you are running A1(6.3a) doesnt support this command.
Syed Iftekhar Ahmed
Overall Rating: 5 (2 ratings)
Syed Iftekhar Ahmed Mon, 10/20/2008 - 10:15
  • Blue, 1500 points or more
This command is in newer codes (2.x) only.
What code are you running?
Are you not seeing this command at all or its there but is not working for you?
Syed Iftekhar Ahmed
new_networker Mon, 10/20/2008 - 10:26
I don't see the command at all. Is this command applicable to global config mode.
The 'show version' output is
Cisco Application Control Software (ACSW)
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2006, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
loader: Version 12.2[121]
system: Version 3.0(0)A1(6.3a) [build 3.0(0)A1(6.3a) adbuild_02:16:25-2008/
02/02_/auto/adbu-rel3/ws/rel_3_0_0_a1_6.3-throttle/REL_3_0_0_A]
system image file: [LCP] disk0:c6ace-t1k9-mz.3.0.0_A1_6_3a.bin
installed license: no feature license is installed
Correct Answer
Syed Iftekhar Ahmed Mon, 10/20/2008 - 10:31
Syed Iftekhar Ahmed
new_networker Mon, 10/20/2008 - 10:35
So, does it mean the only way to change hostname is after removing the FT group and before reinstating it on the standby module.
Correct Answer
Syed Iftekhar Ahmed Mon, 10/20/2008 - 10:41
Syed
