Problem creating new user on 15454
Oct 20th, 2008
I get the error message:
Error creating user
CMSCommFailException: <ip address of node> Communications error (COMM_FAILURE) while attempting to set the SecurityModel::creatUser attribute
After so, the TCC card will auto reset with NO new user.
Can anyone assist me in creating a Retrieve User?
...followed guidelines for user and password length requirements
tphelps Mon, 10/20/2008 - 08:25
A few questions first.
1. What software release?
2. Are you trying to create the user on multiple nodes at once?
3. Are you using a SUPERUSER account to create the user?
tphelps Mon, 10/20/2008 - 08:44
That error is typically associated with a TCC communication problem. If you were successful after the TCC reboot then all should be OK. If you notice this on other nodes, there may be a bug. Mon, 10/20/2008 - 08:47
in order to create the user i did have to bounce all cards on all there may be a bug...
