Unable to activate AAA authentication - Mismatch Detected
Oct 20th, 2008
I've got this really strange problem while I'm tryging to enable Tacacs+ to ACS.
My setup is like this:
(Notice: that I've changed actual username and passwd)
User: admin
Password xyz
Privilege lvl: 15
Network Device Group: CiscoWorks
Server: CWServer
Shared Key: xxxx
And under Administrators I've created CWAdmin with password abc that has full rights to the whole ACS system.
ON Cisco Works LMS 3.0:
User: admin
Password: xyz
and then I start the Setup Center -> Server Setup
select Change ACS Setup
Check Change mode to ACS checkbox and press Next
Fill in the following forms:
Primary IP Address/Hostname:
ACS TACACS+ Port: 49
ACS Admin Name: CWAdmin
ACS Admin Password: abc
Confirm Password: abc
ACS Shared Secret Key: xxx
Confirm key: xxx
System Indentity-
User name: admin
Password: zyx
Then I press Next and I always get the following ACS Connection Status.
Server Status Failed
Primary ACS Verification Status ( )
Tacacs+ Connectivity Reachable
HTTP/HTTPS Connectivity Reachable
AAA Client Configured
Secret Key Verification Mismatch Detected
System Identity User Not Applicable
I've tried almost everything I can think of without luck, I've even tried to have the shared key setting in ACS only the letter "a" to keep it as simple as possible, but I always get this error. I've tried restarts of both ACS and CW Server... I'm basically out of ideas what can be causing this. Help is appreciated if anyone has good ideas what can be causing this...
