Line Group configuration
Oct 20th, 2008
I have a call manager Version 5.1.3.4000-4, I create a Hunt Pilot, Hunt List and Line Group, but I have a problem if in the Line group define Distribution Algorithm with “Longest Idle Time” in the group can't recive two call, and If I define Distribution Algorithm with “Circular” I can recive two calls but when pass a day the group doesn't work how circular, all calls are attend with the one extension, the other extension don't recive call until the first extension is busy.
Is possible with configuration Longest Idle Time recive two calls?
When do I configure Circular don't work fine?
