UNABLE TO DOWNLOAD/FIND COMBINED NET LOCALE INSTALLER 4 CCM6.1 ON CISCO WEB
Answered Question
Oct 20th, 2008
  • Cisco Designated VIP,
    2017 IP Telephony
Guys,
I am trying to install Locales for CCM6.1 cluster, but I cannot find the combined network locale installer on cisco page.
The only locale present is the user locale and from my previous experience as well as the CCM6.1 OS Guide, you need both the Combined networl locale installer and the user locale installer.
Any ideas before go to TAC.
I also observed that under my device pool I do not have the tab for user locale! I only have for netwok Locale!
Correct Answer by allan.thomas about 8 years 5 months ago
The user locale setting is now located within the Common Device Configuration settings under the Device menu.
A common device configuration comprises user-specific service and feature attributes. Ensure that each device is associated with a common device configuration for user-oriented information.
Take a look at the following URL:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmcfg/b06cmdvc.html
Hope this helps..
Rgds
Allan.
Overall Rating: 5 (1 ratings)
Correct Answer
allan.thomas Mon, 10/20/2008 - 08:52
  • Blue, 1500 points or more
Hope this helps..
Rgds
Allan.
allan.thomas Mon, 10/20/2008 - 09:09
Here is the link to the combined Locale Installer 6.1(1.2000-1):-
http://tools.cisco.com/support/downloads/go/IPCheck.x?defAdv=N&sftAdv=N&filename=cm-locale-combined_network-6.1.1.2000-1.cop.sgn&advUrl=null&defInd=N&mdfid=281023410&sftType=Unified+Communications+Manager%2FCallManager+Locale+Installer&optPlat=&nodecount=7&relVer=6.1(1.2000-1)&md5=0c178680227e3068de38c3acd7373fd1&modifmdfid=281023410&imname=&hybrid=Y&imst=N&modelName=Cisco+Unified+Communications+Manager+Version+6.1&treeMdfId=278875240&treeName=Voice+and+Unified+Communications&edesignator=null&nodecount=7&fsd=
User locales are country-specific and are therefore packaged with a matching network locale.
The CUCM Combined Locale Installer combines user locales and network locales in a single file, this is only applicable if your country specific locale is not available.
Rgds
Allan.
Hope this helps.
Ayodeji Okanlawon Mon, 10/20/2008 - 10:33
    2017 IP Telephony
Allan,
Thank you so much! I dont know how I didnt see the file. Thank you also for clearifying the user locale thingy!
allan.thomas Mon, 10/20/2008 - 10:46
No problem at all, thanks for the rating.
Best of luck..
Allan.
