How to synchronize configuration on Cat 6500
Answered Question
Oct 20th, 2008
1. How can I synchronize SUP/MSFC configuration across Cat 6500s
2. How can I verify the synchronize is successful
3. What all elements are synchronized. For e.g. vlan-groups, SVI I believe are not synchronized.
Regards.
Correct Answer by Jon Marshall about 8 years 6 months ago
If you mean between 2 6500 chassis's and you are not running VSS then most of it is a manual process i'm afraid. There are no commands to actually write the configuration across and you wouldn't necessarily want to as one 6500 chassis may well have different ports in different vlans than other.
Some of the service modules do allow synchronization across chassis's eg. the CSM (Content Switch Module) which can write it's configuration from the active switch to the standby switch (active/stanbdy used here in CSM terms only).
Jon
Overall Rating: 5 (1 ratings)
owillins Fri, 10/24/2008 - 08:36
  • Silver, 250 points or more
During normal operation, the startup-config and config-registers configuration are synchronized by default between the two supervisor engines. In a switchover, the new active supervisor engine uses the current configuration.
Further more information about the configure synchronization.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/redund.html#wp1102218
Correct Answer
Jon Marshall Fri, 10/24/2008 - 08:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
