show redundancy states
Oct 20th, 2008
After configuring the SSO on dual cat 6500 chassis, I do not see the peer state as '-STANDBY HOT'.
Please advise why would this happen. SSO is configured by default, and a trunk has been defined between the chassis.
Output:
MYSWITCH#sh redundancy states
my state = 13 -ACTIVE
peer state = 1 -DISABLED
Mode = Simplex
Unit = Primary
Unit ID = 5
Redundancy Mode (Operational) = sso
Redundancy Mode (Configured) = sso
Redundancy State = Non Redundant
Maintenance Mode = Disabled
Communications = Down Reason: Simplex mode
client count = 91
client_notification_TMR = 30000 milliseconds
keep_alive TMR = 9000 milliseconds
keep_alive count = 0
keep_alive threshold = 18
RF debug mask = 0x0
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 10/20/2008 - 10:13
  • Hall of Fame,
    Founding Member
Hello New,
there is no communication between the two supervisors:
the state of the other supervisor is disabled (this is the point of view of the current supervisor)
if this is a VSS the following requirements apply:
A virtual switching system operates with stateful switchover (SSO) redundancy if it meets the following requirements:
•Both supervisor engines must be running the same software version.
•VSL-related configuration in the two chassis must match.
•PFC mode must match.
•SSO and nonstop forwarding (NSF) must be configured on each chassis.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1054565
I would suggest to use a console connection and check if the other supervisor is stucked in rommonitor or other possible issue
Hope to help
Giuseppe
