Enable trunking from cisco3825 router to cisco 3560 switch
Oct 20th, 2008
i am relatively new,so i would like to know how to enable trunking from 3825 router to 3560 switch.
If i am missing any details please let me know.
Overall Rating: 5 (2 ratings)
singhsaju Mon, 10/20/2008 - 11:35
  • Silver, 250 points or more
You can create subinterfaces(corresponding to each vlan) on the router's fastethernet port and configure the port (on the switch) attached to this router as trunk port.
Router
int fas 0/0
speed 100
duplex full
int fas 0/0.10
descr VLAN 10 interface
encap dot1q 10
ip address 192.168.10.1 255.255.255.0
int fas 0/0.20
descr VLAN 20 interface
encap dot1q 20
ip address 192.168.20.1 255.255.255.0
int fas 0/0.30
descr VLAN 30 interface
encap dot1q 30
ip address 192.168.30.1 255.255.255.0
On Switch
int fas 0/1
description Connected to Cisco 3845 fas0/0
switchport mode trunk
switchport trunk encap dot1q
Saju
Pls rate helpful posts
Giuseppe Larosa Mon, 10/20/2008 - 11:40
  • Hall of Fame,
    Founding Member
Hello Ravishankar,
the trunk is configured on the switch side
on the router side for each Vlan where the router has to be member of you configure a vlan subif.
the same trunking method 802.1Q or ISL must be used on both sides
if using 802.1Q the native vlan (=untagged) must match default is vlan 1 on both.
for the switch side use:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010f615.shtml
for the router side:
int f0/0
no ip address
int f0/0.10
enc dot1q 10
ip addr 192.168.10.1 255.255.255.0
int f0/0.20
enc dot1q 20
ip addr 192.168.20.1 255.255.255.0
Hope to help
Giuseppe
rkatikireddy Tue, 10/21/2008 - 05:46
thanks for your quick response and it was very elaborative.
Here is the deal,these two devices(3825 and 3560(24port) are new devices and i have to configure them so they are good to be used for voip.
what are the basic configurations i need on them.
If you can give me step by step,that would be really nice of you.
I have to add a default route on 3825 which would be the ip address of a wan router.
And how would i enable dhcp on both the devices.
Like i mentioned,i am totally new to devices and your help would help me understand at this learning stage.
