WCCP and Multicast
Oct 20th, 2008
We have Juniper WX for compressing the traffice between different location. Currenlty it is in-line position. We would like to set it up "off-path" , which will be connected to 6509 IOS switch. We need to enable the wccp and muticast in the switch. Here is portion of switch configure:
interface GigabitEthernet5/1
description Connection to Core_RTR-Gi5/1
ip address 192.168.210.49 255.255.255.252
interface Vlan2
description Corporate Segment
ip address 192.168.31.252 255.255.255.0
standby 2 ip 192.168.31.254
standby 2 priority 105
standby 2 preempt
The port 5/1 in the switch will be connected to edge WAN router and the Juniper will be connected VLan 2.
How we configure wccp v2 and muticast in 6909 switch? Please help
Giuseppe Larosa Mon, 10/20/2008 - 11:51
  • Hall of Fame,
    Founding Member
Hello Ken,
1) multicast
conf t
ip multicast-routing
int g5/1
ip pim sparse-dense-mode
int vlan2
2) WCCP
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/wccp.html
The following example shows a general WCCPv2 configuration session:
Router# configure terminal
Router(config)# ip wccp web-cache group-address 224.1.1.100 password alaska1
Router(config)# interface vlan 2
Router(config-if)# ip wccp web-cache redirect out
Note: this may fit or not in your scenario use the doc to understand
Hope to help
Giuseppe
