Multicast on 4507 issue
gabewatson
We have several 4507s deployed running
12.2(46)SG Enterprise Services
I am ablel to issue the ip multicast-routing command with no issues, but when I go to enable Multicast on an SVI the
ip pim option is not there. Any ideas on this?
cpubob
What supervisors are you running. I have two 4506's with sup 4's and I have pim.
4506-A#sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M),
Version 12.2(46)SG, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 27-Jun-08 16:24 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11E3C0D8
ROM: 12.1(20r)EW1
Dagobah Revision 95, Swamp Revision 29
4506-A uptime is 4 days, 16 hours, 40 minutes
System image file is "bootflash:"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4506 (MPC8245) processor (revision 7) with 524288K bytes of memory.
Processor board ID FOX073803XX
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from PowerUp
20 Virtual Ethernet interfaces
96 FastEthernet interfaces
8 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
Configuration register is 0x2101
4506-A#conf t
Enter configuration commands, one per line. End with CNTL/Z.
4506-A(config)#int vlan 206
4506-A(config-if)#ip pim sparse-mode
4506-A(config-if)#
SUP IV's
Prichard-4507#sho ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICES-M), Version 12.2(46)SG, RELEASE SOFTWARE (fc1)
Compiled Fri 27-Jun-08 17:28 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11CE63D8
ROM: 12.1(20r)EW1
Prichard-4507 uptime is 24 weeks, 2 days, 15 hours, 30 minutes
Uptime for this control processor is 1 week, 6 days, 18 hours, 58 minutes
System restarted at 22:09:39 cdt Mon Oct 6 2008
System image file is "bootflash:cat4500-entservices-mz.122-46.SG.bin"
cisco WS-C4507R (MPC8245) processor (revision 7) with 524288K bytes of memory.
Processor board ID FOX084001T4
8 Virtual Ethernet interfaces
100 Gigabit Ethernet interfaces
Prichard-4507(config)#int vlan 158
Prichard-4507(config-if)#ip ?
Interface IP configuration subcommands:
access-group Specify access control for packets
address Set the IP address of an interface
admission Apply Network Admission Control
authentication authentication subcommands
bandwidth-percent Set EIGRP bandwidth limit
bgp BGP interface commands
broadcast-address Set the broadcast address of an interface
cef Cisco Express Forwarding interface commands
cgmp Enable/disable CGMP
dhcp Configure DHCP parameters for this interface
directed-broadcast Enable forwarding of directed broadcasts
dvmrp DVMRP interface commands
hello-interval Configures EIGRP-IPv4 hello interval
helper-address Specify a destination address for UDP broadcasts
hold-time Configures EIGRP-IPv4 hold time
igmp IGMP interface commands
information-reply Enable sending ICMP Information Reply messages
irdp ICMP Router Discovery Protocol
load-sharing Style of load sharing
local-proxy-arp Enable local-proxy ARP
mask-reply Enable sending ICMP Mask Reply messages
mrm Configure IP Multicast Routing Monitor tester
mroute-cache Enable switching cache for incoming multicast packets
mtu Set IP Maximum Transmission Unit
multicast IP multicast interface commands
next-hop-self Configures EIGRP-IPv4 next-hop-self
nhrp NHRP interface subcommands
ospf OSPF interface commands
pgm PGM Reliable Transport Protocol
policy Enable policy routing
probe Enable HP Probe support
proxy-arp Enable proxy ARP
rarp-server Enable RARP server for static arp entries
redirects Enable sending ICMP Redirect messages
rgmp Enable/disable RGMP
rip Router Information Protocol
route-cache Enable fast-switching cache for outgoing packets
router IP router interface commands
sap Session Advertisement Protocol interface commands
security DDN IP Security Option
split-horizon Perform split horizon
sticky-arp Allow the creation of sticky ARP entries
summary-address Perform address summarization
tcp TCP interface commands
unnumbered Enable IP processing without an explicit address
unreachables Enable sending ICMP Unreachable messages
vrf VPN Routing/Forwarding parameters on the interface
wccp WCCP interface commands
