ASA reports
Oct 20th, 2008
Good Afternoon:
Someone know if i can get reports from the Cisco Security Manager, as mayor port's used, mayor rules used, mayor denys, an graphics?
If not is posible wich software can do it?
Farrukh Haroon Mon, 10/20/2008 - 21:52
MARS would be the number one choice if your firewall is from Cisco. Juniper also has a SIM now. This is from a previous post:
Have you looked at Cisco MARS? (Its actaully a SEM)
http://www.cisco.com/en/US/products/ps6241/products_data_sheets_list.html
http://www.sawmill.net/features.html
(Found it to be pretty nice, but might be pricy)
If you want a real-time thing, fireplotter is pretty cool:
www.fireplotter.com
Alternates:
http://manageengine.adventnet.com/products/firewall/
(never tried it tough)
http://www.eventid.net/firegen/firegenpix2.asp
(had serious performance issues)
Some more:
http://www.windowsecurity.com/software/Firewall-security-log-analyzers/
Please rate if helpful
Farrukh
colonha27 Tue, 10/21/2008 - 05:06
Thanks very much. I see this recomendations.
Cordially
Hector
colonha27 Tue, 10/21/2008 - 05:17
Thank's Farrukh:
Maybe you know some software freeware?.
Thank's in advanced.
Farrukh Haroon Tue, 10/21/2008 - 05:23
You can get an evaluation version of fireplotter or others. It works without some advanced features.
The problem is that netflow is only supported on the high end ASA boxes, otherwise there are a few free netflow collectors out there.
Farrukh
