EZVPN Client can PING remote hosts but can't access SMB shares
Oct 20th, 2008
I've recently created a VPN configuration on a 1721-K9 router running IOS (C1700-ADVSECURITYK9-M), Version 12.4(15)T7. The Windows XP SP2 client running Cisco VPN Client 5.0.04.033 can connect and ping hosts on the remote LAN but can't access SMB shares or telnet to hosts. I've turned off the Windows Firewall and removed the ACL on the router's upstream interface. The VPN client is behind another 1721 with NAT. Any ideas, anyone?
Here are the relevant portions of the IOS configuration:
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
lifetime 600
crypto isakmp keepalive 20 5
crypto isakmp nat keepalive 20
crypto isakmp client configuration address-pool local VPN-pool
crypto isakmp client configuration group VPN-group
key groupkey
dns dns1.ip dns2.ip
wins 10.0.1.250
domain domain.com
pool VPN-pool
acl 150
access-list 150 permit ip 10.0.1.0 0.0.0.255 10.0.2.0 0.0.0.255
crypto ipsec transform-set transform-1 esp-3des esp-sha-hmac
crypto dynamic-map dynmap 1
set transform-set transform-1
reverse-route
crypto map dynmap isakmp authorization list VPM-group
crypto map dynmap client configuration address respond
crypto map dynmap 1 ipsec-isakmp dynamic dynmap
crypto ctcp port 10000
archive
log config
hidekeys
interface Loopback0
ip address 10.0.2.1 255.255.255.0
interface FastEthernet0
description configuration setup IP
ip address 10.0.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
speed auto
no cdp enable
interface Serial0
bandwidth 1540
ip address serial.ip 255.255.255.252
ip nat outside
no fair-queue
no cdp enable
crypto map dynmap
ip local pool VPN-pool 10.0.2.2 10.0.2.254
ip route 0.0.0.0 0.0.0.0 Serial0
ip nat inside source list 1 interface Serial0 overload
ip nat inside source static 10.0.1.208 public.113
ip nat inside source static 10.0.1.249 public.114
ip nat inside source static 10.0.1.250 public.115
ip nat inside source static 10.0.1.77 public.116
access-list 1 permit 10.0.1.0 0.0.0.255
