easy question for the pros!!!!
cisco steps
can any one explain to me what this mean, I am trying to learn about the config on Voice gtwy...line by line if possible , Thanks
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime
logging buffered 1000000 debugging
aaa authentication login Remote group radius enable
aaa session-id common
Giuseppe Larosa
Hello ocporbust,
instructs the router to use for the debug messages timestamps that contain the datetime (other option is uptime) with millisecond resolution using the local-time (GMT is default) and showing the timezone name.
instructs the router to use for the log messages timestamps that contain the datetime (other option is uptime) with millisecond resolution using the local-time (GMT is default)
instructs the router to create a local text buffer of 1000000 chars and to log messages up to debug level (= all possible messages)
you can see the buffer with sh log
in aaa new-model creates an ordered list of authentication methods to be used for the login called Remote: the method is the group of radius servers defined on the router
to use a single session id for AAA = authentication authorization and accounting
Hope to help
Giuseppe
Giuseppe Larosa
Hello ocporbust,
Hope to help
Giuseppe
Man Thank you, I figured out that is the only way I am going to learn @ work , can I submit a config of a router ( small config ) and you can help on translating what you can from it.. Thanks
