iBGP question
oswaldo81
does anybody know if the following is possible.........
1. I have server X (just a made up name) with an iBGP session to a Cisco router.
2. Server X announces routes to the router with no-advertise and no-export communities set - the router enforces this with an inbound route-map.
3. The router has an iBGP session with a route log server as well a many other iBGP sessions to other routers.
Q. When the router receives a route with the communities set as in 2 from server X, is it possible to make the router advertise this route only to the route log server (for route audit purposes) but to honour the no-advertise community for all other iBGP peerings?
It is not possible to make the server iBGP peer directly with the route log server because the server X cannot be trusted.
Ideally, I don't want to be putting lots of outbound filters on all of the routers iBGP peerings.
Thanks for your time!
Alan
Giuseppe Larosa
Hello Alan,
you should remove the no-advertise community on the inbound route-map when the prefix is received, but then you need to use a route-filter to avoid to send it to all other iBGP peers.
So the short answer should be no without route-filters or all iBGP receive it for the inbound removal of no-advertise or none will receive it if you leave the no-advertise community untouched
Hope to help
Giuseppe
