Recover WAAS on CManager
Oct 20th, 2008
After changing network config I cause my CM to loose site of the WAAS modules. See screenshot. Is there any command/function to recover this other than rebooting all devices?
I can see a "show cms info" and a number of "cms....." exec commands. None seem to do the trick..
dstolt Mon, 10/20/2008 - 17:17
  • Cisco Employee,
Even better. Good job.
Dan
dstolt Mon, 10/20/2008 - 17:16
  • Cisco Employee,
Shaun,
Your edge WAEs should be registered to the CM using the command "central-manager address xxxxxx" using either the IP address or devicename.domain.com if you are using DNS (recommended). If you are using the IP address, you may need to update it to the new IP address you are using for the CM.
Hope that helps,
Dan
