Accessing Bogan Paging System
Oct 20th, 2008
Is there a way to broadcast a message through our Bogan Pagaing System that you access via the Avaya PBX. You can access it on a digital Avaya Phone by dialing a three digit number. Is there a way to access it with a Cisco IP phone that connects to the Avaya PBX via an ISDN Line?
Chris Deren Mon, 10/20/2008 - 16:28
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Sure simply create a route pattern that points to the Avaya trunk and dial it, ensure the dialed digits are pointing to the paging system on Avaya side.
Chris
Mojo1 Tue, 10/21/2008 - 11:44
I created a route pattern called 776 which is the three digit number used to access the PA Paging System.
When I dial this from an IP Phone is says your call can not be completed as dialed.
What else do I need to do?
