SHDSL
Oscar Cardiel
Hello guys,
I am trying to configure a shdsl module but I don't get to up the Atms interfaces created. I think is a wire problem because I see the following message when the show controller shdsl command.
Controller SHDSL 0/3/0 is UP
Group (0) info:
Type: 4-wire g.shdsl, status: Configure Firmware
Interface: ATM0/3/0, hwidb: 0x6489FDD0, UTOPIA phy 0
Configured/active num links: 2/0, bit map: 0x3/0x0
Line termination: CPE, line mode: 4-wire, Annex-A, PMMS disabled
Line coding: 16-TCPAM, configured/actual rate: 4608/0 kbps
SHDSL wire-pair (0) is in DSL DOWN state
Termination: CPE, line mode: 4-wire, Annex-A
Line coding: 16-TCPAM, configured/actual rate: 2304/2048 kbps
CONNECT state: MAIN_PRE_ACT, cond: EXCEPTION, reason: NOT_CONVERGED_ON_SC
SHDSL wire-pair (1) is in DSL DOWN state
CONNECT state: MAIN_INIT, cond: EXCEPTION, reason: NOT_CONVERGED_ON_SC
My configuration is the following:
controller SHDSL 0/3/0
termination cpe
dsl-group 0 pairs 0, 1
shdsl 4-wire mode enhanced
shdsl annex A
shdsl rate 4608
dsl-group 1 pairs 2, 3
shdsl annex A
shdsl rate 4608
interface ATM0/3/0
no ip address
ip route-cache flow
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 2
interface ATM0/3/1
no ip address
ip route-cache flow
no atm ilmi-enable
pvc 8/35
dialer pool-member 4
with their Dialers configuration.
What do you think about?
thank you very much in advance.
28 Replies 28
p.mafara
I've got the same problem :)
WAN, Routing and Switching: shdsl
Posted by: p.mafara - SUPERTRONIC SPA
Oct 21, 2008, 4:08am PST
Giuseppe Larosa
Hello Oscar and Patrizio,
it can be a cabling problem.
this SHDSL controller uses 4 wires out of or 8 wires.
so pairs 0,1 makes the first SHSDL link
pairs 2, 3
So actually if the external connector is an RJ-45 all 8 wires are to be used.
So check the cable you are using:
If you have an NT I should try to use an RJ-45 straigh cable (like a LAN cable)
if you have multiple NTs you may need to build a custom cable.
a reference doc is
http://www.cisco.com/en/US/docs/ios/12_4/interface/configuration/guide/h4wire.html#wp1052661
Hope to help
Giuseppe
Hello Giuseppe,
i'm using a cable built this way :
Router Telco
RJ45 RJ11
6
line0 5 ------ 4 cp1
line0 4 ------ 3 cp1
line1 2 ------ 5 cp2
line1 1 ------ 2 cp2
The reference doc for the hwic-4shdsl is
http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/shdslfm.html
I've tried also the original cisco cable and
swapped cp1 with cp2 , but no succes , see output :
Controller SHDSL 0/0/0 is UP
Hardware is HWIC-4SHDSL, rev 2 on slot 0, hwic slot 0
Capabilities: IMA, M-pair, 2/4 wire, Annex A, B, F & G, CPE termination
cdb=0x637160EC, plugin=0x636EEE04, ds=0x636FAC88 base=0x50400000
FPGA Version is REL.3.4.0, NIOSII FW:Ver 2.9, status Running
SDC-16i HW:Rev 1.2, status UP, FW:Ver 1.2-1.1.3__57, status Running
SDFE-4 HW:Rev 1.2, status UP, FW:Ver 1.1-1.5.2__001 , status Running
NIOSII Firmware image: System
SDC16i Firmware image: System
SDFE4 Firmware image: System
Number of pairs 4, number of groups configured 2
Ignored CLI cmds(0), Event buffer: in use(0), failed(0)
Group (0) info:
Interface: ATM0/0/0, hwidb: 0x63716338, UTOPIA phy 0
Line termination: CPE, line mode: 4-wire, Annex-A-B, PMMS disabled
Line coding: 16-TCPAM, configured/actual rate: AUTO/0 kbps
Termination: CPE, line mode: 4-wire, Annex-A-B
Line coding: 16-TCPAM, configured/actual rate: AUTO/2048 kbps
CONNECT state: MAIN_DATA_MODE, cond: GHS_TRANSFER, reason: ERR_NONE
Power back off: 2dB, FE power back off: 0dB
LoopAttn: 32dB, SnrMargin: 255dB, Status noDefect
Current 15 minute statistics (Time Elapsed 738 seconds):
ES: 0, SES: 0, CRC: 0, LOSWS: 201, UAS: 49
Previous 15 minute statistics:
ES: 0, SES: 0, CRC: 0, LOSWS: 251, UAS: 63
Current 24 hr statistics:
ES: 0, SES: 0, CRC: 0, LOSWS: 753, UAS: 188
Previous 24 hr statistics:
ES: 0, SES: 0, CRC: 0, LOSWS: 0, UAS: 0
ATM-TC Tx: data cells: 0, Idle/Unassigned: 0
ATM-TC Rx: data cells: 73590, uncorr HEC: 0, corr HEC: 0
ATM-TC Rx: OCD: 0, LCD start: 0, LCD end: 0
SHDSL wire-pair (1) is in DSL config state
CONNECT state: MAIN_INIT, cond: NONE, reason: ERR_NONE
Power back off: 0dB, FE power back off: 0dB
LoopAttn: 0dB, SnrMargin: 0dB, Status noDefect
Current 15 minute statistics (Time Elapsed 0 seconds):
ATM-TC Rx: data cells: 0, uncorr HEC: 0, corr HEC: 0
For Oscar ,
have you tried yours and the following config also without shdsl 4-wire mode enhanced ?
termination cpe
shdsl annex A-B
shdsl rate auto
shdsl annex A-B
shdsl rate auto
Patrizio
Hello Patrizio,
you are configuring two HDSL each of them uses two pairs = 2+2 four wires (four wires mode means this)
so you need to use all 8 wires in a RJ-45 cable.
How to connect the 8 wires is the next step
may be you need to start from the specifications for RJ-45
for example
http://www.zytrax.com/tech/layer_1/cables/tech_lan.htm#100s
Hope to help
Giuseppe
Hi Giuseppe and Patrizio
First of all, thank you in advance for your help.
I have checked the pin-out cable and it is correct. For Patrizio; I have tried mine to configure without shdsl 4-wire but this wasn't working.
It is curious but if I connect the ISP routers those work fine, so the ISP line is OK too. I can't get access to those routers for checking the configuration. The ISP routers are both two Telindus 1421.
Hi Giuseppe,
i'm configuring one HDSL 4-wire 4mb with one group , two pair that use 2 wire = 4 wire so I need to use only 4 wires of a RJ-45 cable.
Regarding the schematic it didnt come out right but i can tell you that I'm using also Cisco cable 37-0860-01, the pinout is exactly as Figure 5 Standard RJ-45 Connector to Two Standard RJ-11 Connectors of document :
http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/shdslfm.html , of wich i'm using only one of the two RJ11 marked Ports 0,1 on the cable .
I've been doing cable for years when nodoby knew how to do a cross-cable , i came up with a cross baseT1000 when cisco cables crossed only 4 pairs and the others where straight.
(The first cross-cable i've done where with green cap , the second version all green including the cable , this is why now near all crossed cable sold are green.)
Maybe we cannot use the HWIC-4SHDSL with 4 wire and must use the HWIC-2SHDSL ?
Patrizio
Hi Giuseppe and Oscar,
just to let you know Telecom Italia is the provider of the BitStream line . This morning their technician come to test the line with an Aethra AC2037 , the line its OK and he told me that the Italtel DSLAM to wich we are connected does not care if the line are swapped , in fact he tried one way or the other with the AC2037 .
Also i received a WIC-1SHDSL-V3 , hereunder are the test with the same line i'm trying to make it work with the HWIC-4SHDSL .
#sh run
controller DSL 0/1/0
mode atm
line-term cpe
line-mode 4-wire standard
dsl-mode shdsl symmetric annex B
ignore-error-duration 30
snr margin current disable
snr margin snext disable
line-rate 4096
#sh controllers dsl 0/1/0
DSL 0/1/0 controller UP
Globespan xDSL controller chipset
Line Mode: Four Wire Standard
DSL mode: Trained with SHDSL Annex B
Frame mode: Utopia
Configured Line rate: 4096Kbps
Line Re-activated 0 times after system bootup
LOSW Defect alarm: ACTIVE
CRC per second alarm: ACTIVE
FPGA Revision: 0xB3
Line 0 statistics
Current 15 min counters
CRC : 0 LOSW Defect : 0 ES : 0 SES : 0 UAS : 419
Previous 15 min counters
CRC : 0 LOSW Defect : 0 ES : 0 SES : 0 UAS : 0
Current 24 hr counters
Previous 24 hr counters
Line 1 statistics
CRC : 0 LOSW Defect : 0 ES : 0 SES : 0 UAS : 389
Line-0 status
Chipset Version: 0
Firmware Version: R4.2.1
Modem Status: Data, Status 1
Last Fail Mode: No Failure status:0x0
Line rate: 2056 Kbps
Framer Sync Status: In Sync
Rcv Clock Status: In the Range
Loop Attenuation: 5.2 dB
Transmit Power: 12.5 dB
Receiver Gain: 19.5420 dB
SNR Sampling: 39.3690 dB
Receive HEC Error Count: 0
Line-1 status
Chipset Version: 0
Loop Attenuation: 5.4 dB
Receiver Gain: 20.2420 dB
SNR Sampling: 39.5920 dB
Dying Gasp: Present
Patrizio
i've made some more test.
On the first test telco-line goes to two group slave pairs 1 and 3 wires .
If the telco-line goes to the two group master pairs 0 and 2 it does not change anything.
controller SHDSL 0/0/0
termination cpe
dsl-group 0 pairs 1
shdsl annex B
shdsl rate 2304
dsl-group 1 pairs 3
shdsl annex B
shdsl rate 2304
As you can see it gets the speed line -coding on both pair but no atm cells packet .
4wiretest#sh controllers shDSL 0/0/0
cdb=0x63639EA4, plugin=0x63612A04, ds=0x6361EA40 base=0x50400000
Group (0) info:
Type: 2-wire g.shdsl, status: Configure Firmware
Interface: ATM0/0/0, hwidb: 0x6363A0F0, UTOPIA phy 0
Configured/active num links: 1/0, bit map: 0x2/0x0
Line termination: CPE, line mode: 2-wire, Annex-B, PMMS disabled
Line coding: 16-TCPAM, configured/actual rate: 2304/0 kbps
Termination: CPE, line mode: 2-wire, Annex-B
CONNECT state: MAIN_PRE_ACT, cond: FOUR_WIRE_DET, reason: ERR_NONE
Power back off: 2dB, FE power back off: 1dB
Current 15 minute statistics (Time Elapsed 484 seconds):
Group (1) info:
Interface: ATM0/0/1, hwidb: 0x636A1404, UTOPIA phy 1
Configured/active num links: 1/0, bit map: 0x8/0x0
SHDSL wire-pair (3) is in DSL DOWN state
Current 15 minute statistics (Time Elapsed 495 seconds):
i've made another test .
On the second test telco-line pair 0 goes to router pair 0-3 and telco-line pair 1 goes to router pair 1-2 .
The same work if i put telco-line pair 0 to 0-2 and telco-line pair 1 to pair 1-3.
termination cpe
shdsl annex B
shdsl rate auto
cdb=0x635AC424, plugin=0x63584F84, ds=0x63590FC0 base=0x50400000
Number of pairs 4, number of groups configured 1
Group (0) info:
Type: 4-wire g.shdsl, status: UP
Interface: ATM0/0/0, hwidb: 0x635AC670, UTOPIA phy 0
Configured/active num links: 2/2, bit map: 0x3/0x3
Line termination: CPE, line mode: 4-wire, Annex-B, PMMS disabled
Line coding: 16-TCPAM, configured/actual rate: AUTO/4096 kbps
SHDSL wire-pair (0) is in DSL UP state
Termination: CPE, line mode: 4-wire, Annex-B
LoopAttn: 13dB, SnrMargin: 22dB, Status noDefect
Current 15 minute statistics (Time Elapsed 701 seconds):
ES: 1, SES: 1, CRC: 0, LOSWS: 7, UAS: 0
ATM-TC Tx: data cells: 124756, Idle/Unassigned: 82726785
ATM-TC Rx: data cells: 195423, uncorr HEC: 95, corr HEC: 0
ATM-TC Rx: OCD: 10, LCD start: 1, LCD end: 1
SHDSL wire-pair (1) is in DSL UP state
CONNECT state: MAIN_DATA_MODE, cond: GHS_STARTUP, reason: ERR_NONE
LoopAttn: 13dB, SnrMargin: 18dB, Status noDefect
Current 15 minute statistics (Time Elapsed 609 seconds):
ES: 3, SES: 3, CRC: 0, LOSWS: 8, UAS: 0
Group (1) is Not configured.
Its a tweak , its strange but somehow it can sync the line if both pair 0 and 2 receive the signal , but of course it needs the other two pairs to complete the 4-wire handshake.
Patrizio
Hello Patrizio,
good news you have found a cabling setup that works and you have reported here.
we can say that with 6 wires you can use only a single 4wire group (this is easy to say) but you have found how to connect with tests.
Best Regards
Giuseppe
Hello Giuseppe,
in fact what i've found it that the HWIC-4SHDSL is unable to work with 1 dsl-pair group or 4 wires , it need all the 8 wires to sync even if your line its 4 wire . For this purpose i've used the original cisco cable CAB-RJ45-2RJ11 p/n 37-0860-01 using both RJ11 and attach them to a RJ11 Doubler http://www.run-it-direct.co.uk/images/RJ11Doubler.jpg .
Of course this should be not the normal way for the HWIC to work , there is something wrong with it , in fact i've also a TAC case pending , i hope the will open an escalation for the bug because the line its flapping every 50 minute .
Please note this
#sh controllers shDSL 0/0/0 detailed
grp 0, tsnid 1, linkmap 0xc, flags 0x00, imacmd 0, realMWMaster 2
grp 1, tsnid 0, linkmap 0x0, flags 0x00, imacmd 0, realMWMaster 0
ch 0, state 4, substate 0, conntype 1, mwire 0, realMwMaster 0
ch 1, state 4, substate 0, conntype 1, mwire 0, realMwMaster 0
ch 2, state 5, substate 12, conntype 1, mwire 1, realMwMaster 2
ch 3, state 5, substate 12, conntype 1, mwire 1, realMwMaster 2
Thanks and Best Regards,
Patrizio
Hello Giuseppe and Oscar,
just to keep updated , with the latest version of IOS c1841-ipbasek9-mz.124-22.T.bin now the board seems to work as it should be , using only 4 wire with the original cisco cable that came with the board , and with the
configuration stated on the manual .
termination cpe
dsl-group 0 pairs 0,1
shdsl annex B
shdsl rate auto
The only problem is that sometime the line freeze in the up state and you cannot ping the atm inferface , and sometime the ping latency goes up to ten times the normal expected value , say form 8/12msec to 120/200msec .
Patrizio
Dear All,
I have the same problem with 8Mbps IMA (Telecom Italia) with a Cisco 2911 with this card: EHWIC-4SHDSL-EA.
Controller is UP but SHDSL wire-pair 0,1,2,3 is DOWN.
I've tried various cabling without success.
Can someone help me?
Salvatore
Dear Salvatore,
did you try different IOS version ?
Sometime with Telecom Italia some version do not work , and sometime also some adsl/hdsl router do not work .
Patrizio
