CallManager Upgrade - 3.3(5) to 4.1(3) question
Oct 20th, 2008
Can i upgrade from CallManager 3.3(5) to 4.1(3) using the version of 4.1(3) available in the voice download section on CCO ??
Jaime Valencia Mon, 10/20/2008 - 18:14
no, any upgrade from 3.X to 4.X requires physical media
you need the actual CDs to do this, the SW download is only if upgrading from 4.0(2a) or 4.1(2)
if this helps, please rate
glenncarter Mon, 10/20/2008 - 19:11
Thanks Java ... can you tell me is there a difference between the physical media for upgrading as apposed to installing a fresh installation?
i.e. is the version of 4.1(3) disks for upgrading from 3.3(5) different to the 4.1(3) disks used in a fresh install. (i am assuming there is)
i only ask because i can get my hands on a set of disks that were used to build a 4.1(3) cluster from scratch.
