10-20-2008 06:38 PM - edited 03-15-2019 02:04 PM
We did a factory reset on a 7940 and the password is now option 8 versus the original setting of 9. Furthermore, cisco does not work as the password. Has anyone ever seen this happen and what the fix is?
10-24-2008 08:34 AM
In order to perform a factory reset of a phone if the password is set, complete these steps:
Unplug the power cable from the phone, and then plug in the cable again.
The phone begins its power up cycle.
1.Immediately press and hold # while the Headset, Mute, and Speaker buttons flash in sequence.
Release # after the Speaker button is no longer lit.
The Headset, Mute, and Speaker buttons flash in sequence in order to indicate that the phone waits for you to enter the key sequence for the reset.
2. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you repeat a key within the sequence, for example, if you press 1223456789*0#, the sequence is still accepted and the phone resets.
3. If you do not complete this key sequence or do not press any keys, after 60 seconds, the Headset, Mute, and Speaker buttons no longer flash, and the phone continues with its normal startup process. The phone does not reset. If you enter an invalid key sequence, the buttons no longer flash, and the phone continues with its normal startup process. The phone does not reset.
If you enter this key sequence correctly, the phone displays this prompt:
Keep network cfg? 1 = yes 2 = no
In order to maintain the current network configuration settings for the phone when the phone resets,
press 1. In order to reset the network configuration settings when the phone resets, press 2.
If you press another key or do not respond to this prompt within 60 seconds, the phone continues with
its normal startup process and does not reset. Otherwise, the phone goes through the factory reset
process.
4. In order to maintain the current network configuration settings for the phone when the phone resets,
process.
10-24-2008 11:21 AM
I appreciate your response, but I have done a factory reset MANY times already. Now the password is number 8 instead of 9 and it does not accept any password that I have tried such as cisco, Cisco, CISCO, Pass, Password etc.
