Cache Engine- ce7305-5.5.1.7
itssnsu07
i have a problem writing to the memory on ce7305-5.5.1.7 configured as cache,
i get an error,
"Copy running-config to startup-config failed!. status(1.20)"
Please advise!
Thank You and Kind Regards,
ET
sbilgi
Level 5
Level 5
Possible causes are Ram disk full - unable to create the temporary file in /tmp and not able to connect to the dataserver to get the running configuration. There are some similar issues that would be resolved on the current version that you are running such as:
CSCea06998: DataFeedPoll - race condition when writing config to flash
CSCdy77684: returns error, need more description while writing flash
This sort of issue may occur when other application is using the flash while other code was trying to access it.
A show flash command sometimes provide more information on this failure so lets get the output of it to see how it comes up on it.
Hello, here is the output for sh flash:
ce1#sh flash
ACNS software version (disk-based code): ACNS-5.5.1-b7
System image on flash:
Version: 5.5.1.7
System flash directory:
System image: 105 sectors
Bootloader, rescue image, and other reserved areas: 27 sectors
256 sectors total, 124 sectors free.
Genet T.
