upgrade cucm from 6.1.2-1000 to 6.1.2-1107
Oct 20th, 2008
I did upgrade from 6.1.2-1000 to 6.1.2-1107. From "OS Administration"->show->software, it says active version is still 6.1.2-1000, but "installed software option" is cmterm-devicepack6.1.2.1107-1.cop, what do that means? how can I make 6.1.2.1107 as active version?
Thanks.
mikram Tue, 10/21/2008 - 00:24
  • Bronze, 100 points or more
On the OS platform, try the following command
util system switchover, it will make inactive version active. You can also do that from GUI, but I prefer from CLI interface.
Good Luck.
Ikram
hansyin Tue, 10/21/2008 - 11:57
Thanks.
that function can only switchover active and inactive version. In my case, select "version", it shows my active version is 6.1.2.1000, inactive version is 6.1.1.2000, and I have another "installed software option" which is 6.1.2.1107, and it was shows "active" state. I don't understand what's that meaning. the home page still shows current version is 6.1.2.1000. I don't know if 6.1.2.1107 is working.
The switchover function can only switch version between 6.1.2.1000 and 6.1.1.2000.
Anybody can help me? thanks.
hansyin Wed, 10/29/2008 - 23:12
Is there somebody can help me to figure out this problem? thanks.
