IDSM2 System Image Upgrade
Oct 20th, 2008
Dear all,
Current running System Image is 6.0(1)E1, whether I can upgrade direct to 6.1(1)E2 or I have to go step by step like 6.0(2)E1 and then next. In addition I want to know if I upgrade, the current configuration will lose or not. kindly
thanks & regards,
Farrukh Haroon Tue, 10/21/2008 - 05:45
From Cisco:
"The minimum required version for upgrading to 6.1(1) is 5.0(1) or later, which is available as a download from".
You won't loose any configs but just keep a backup handy and check the release notes for any particular caveats related to your specific platform:
zakid Tue, 10/21/2008 - 20:17
many thanks.....
Dear after I upgrade from 6.0(1)E1 to 6.0(2)E1 the sensor restart and gone to status other, after a while the status showing powerdown. will you please show me how to rectify.
thanks & regards
Farrukh Haroon Tue, 10/21/2008 - 22:52
Try one of the following:
hw-module module 5 boot 0
hw-module module 5 boot 1
hw-module module 5 boot 2
Whichever works :)
zakid Thu, 10/23/2008 - 03:35
Hai dear, thanks for your comments.....
unfortunately i have to complete this task very urgent. so I reimage system files 6.1(1)E1. its working fine.
thanks & Regards,
