IPCCX Cluster
Answered Question
Oct 21st, 2008
We have 2 IPCCX 5.0 servers in a cluster.
I like to know if we will be able to make changes to the config (such as adding/deleting an agent) when the primary ipccx server goes down.
Does the IPCCX Cluster work the same way as 4.x and 5.x CCM Cluster?
Many Thanks,
Correct Answer by tim.giles about 8 years 4 months ago
Yes UCCX 5.0 supports HA (high availability) therefore you can do this.
Is SQL co-resident or on an expansion server (on a different box than both the UCCX servers)?
Correct Answer by mikram about 8 years 4 months ago
Yes, you can make changes while the second server is up and running. I hope you are using SQL 2K with sp4.
cheers
Ikram
Overall Rating: 5 (2 ratings)
Correct Answer
mikram Tue, 10/21/2008 - 01:13
cheers
Ikram
Correct Answer
tim.giles Tue, 10/21/2008 - 01:32
araffill Tue, 10/21/2008 - 08:03
Hi Tim,
Tx a lot for the reply.
The SQL server is co-resident.
Tx again.
