CWLMS-2.2-K9
Answered Question
Oct 21st, 2008
What is the difference between these 2 products?
CWLMS-2.2-K9 LAN Managment 2.2 for WIN/SOL; CM, DFM, RME, RTM, CV
and
CWRW-1.3-K9 Routed WAN Mgmt 1.3 for WIN/SOL; ACL, IPM, RME, CV
Thank you.
Correct Answer by m.sir about 8 years 8 months ago
Hello its two different products.. LMS has different modules (it what abbreviations CM, DFM means) some are used for LAN only (DFM) and some for WAN networks (ACL)
CM - campus manager
http://www.cisco.com/en/US/products
DFM - device fault manager
http://www.cisco.com/en/US/products/sw/cscowork/ps2421/index.html
RME - resource manager essential
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/index.html
ACL - access control list manager
http://www.cisco.com/en/US/products/sw/cscowork/ps402/products_data_sheet09186a0080092440.html
RTM - real time monitor
http://www.cisco.com/en/US/products/sw/cscowork/ps2803/products_data_sheet09186a0080088837.html
CV - cisco view
http://www.cisco.com/en/US/products/sw/cscowork/ps4565/index.html
Those products have same just RME (used for config backup, system upgrades etc..) and CV (used for device viewing )
So basically CWLMS-2.2-K9 LAN Managment is used for LANs and CWRW-1.3-K9 Routed WAN Mgmt is for WAN environment
Hope that helps rate if it does
M.
Overall Rating: 5 (1 ratings)
Correct Answer
m.sir Tue, 10/21/2008 - 03:27
  • Gold, 750 points or more
CM - campus manager
CV - cisco view
M.
