DFM starts, but not working
klepikov_a
Hi all!
I have a problem with fresh install of LMS 3.1 on fresh Windows 2003 Server Standart Edition with SP1. LMS install finishes without errors. All services are up and running after reboot. On DFM home page I see message
An exception occurred.Please check the AAD.log file for further details.
AAD.log is attached
DFM does not work at all. For example, if I add device, its status will be "Learning" all the time.
Everything else works good. Is there a way to fix this problem?
This indicates a problem connecting to the DfmServer. Check the fully-qualified hostname of this server under My Computer > Properties > Computer Name. Make sure this hostname is resolvable:
NMSROOT\bin\perl NMSROOT\bin\resolver.pl HOSTNAME
If not, you must make this fully-qualified hostname resolvable, then restart CiscoWorks Daemon Manager.
6 Replies 6
Joe Clarke
Please post the output of pdshow. At what percentage are the devices? You can see this under DFM > Device Management > Rediscover/Delete.
klepikov_a
I added 1 device yesterday. Time zone is EEST = UTC +3. My local time now is 22 Oct 9:12am
IP Address = *.*.*.*
DNS Name = *.*.com
Device Status = Learning
Device Type = N/A
Aliases = N/A
Containments = N/A
DFM Processing = N/A
Time Last Discovered = N/A
Import Time Stamp = 21-Oct-2008 13:18:29
*** Data Collector Status Information ***
Discovery Progress = 10% completed
Error Code = N/A
Error Message = N/A
pdshow output is attached.
I have similar problem, but in my case hostname resolution works fine.
As next step I will open a TAC Case, but maybe there is quick fix known for someone ;)
Windows/DFM ver 3.0.4
Seba
Please start a new thread for your issue.
klepikov_a
Oh thank you VERY MUCH! Now it works!
