RESTORE BACKUP IN LMS 2.6
Answered Question
Oct 21st, 2008
Hi Friends
plse let me know how to restore backup for LMS 2.6.
Correct Answer by Joe Clarke about 8 years 4 months ago
This backup procedure works for all applications except IPM. For IPM, you will need to run the "ipm dbrestore" command.
PROGRA~1 is the DOS 8.3 abbreviation for "Program Files". You should always use the 8.3 path names when working with LMS on Windows. C:\PROGRA~1\CSCOpx is the default location where LMS is installed on Windows. The example commands I posted are complete commands. You would only need to adjust them for the paths used on your server.
Shutdown the CiscoWorks Daemon Manager, then run:
NMSROOT/bin/perl NMSROOT/bin/restorebackup.pl -d /path/to/backup
If there is a generation number, you also need to specify "-gen NUMBER". For example, on Windows:
C:\PROGRA~1\CSCOpx\bin\perl C:\PROGRA~1\CSCOpx\bin\restorebackup.pl -d C:\backups
Solaris:
/opt/CSCOpx/bin/perl /opt/CSCOpx/bin/restorebackup.pl -d /backups/lms
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Tue, 10/21/2008 - 09:37
Solaris:
vaibhav-g Tue, 10/21/2008 - 21:47
this solution is applicable for all LMS versions.plse mention the backup procedure also.
plse re-write this command more clearlly.
PROGRA~1 WHAT DOES THIS MEAN,PLSE SPECIFY FULL COMMAND.
Vaibhav
Correct Answer
Joe Clarke Tue, 10/21/2008 - 22:01
vaibhav-g Tue, 10/21/2008 - 22:31
Thanks a lot for all those information.
plse let me know the exact procedure for backup in LMS 2.6.
Vaibhav
Joe Clarke Wed, 10/22/2008 - 08:45
The backups can be taken through the GUI under Common Services > Server > ADmin > Backup.
vaibhav-g Wed, 10/22/2008 - 21:39
Thanks a lot...
i have dine the same it works..
Thank you so much.
Vaibhav
