10-21-2008 06:21 AM - edited 03-06-2019 02:03 AM
what is the command for failing over the sup? and can i set the time it takes for failover?
thanks
10-21-2008 06:49 AM
redundancy force-switchover will force the switch to fail over the supervisor. I am not sure what you are asking about setting the time - do you mean scheduling the failover - failver in 10 mins sort of thing? If so I don't believe you can do that.
10-21-2008 07:02 AM
Further to the good information by Paul, the failover duration depends on the supervisor and the mode of redundancy that has been configured, it cannot be predetermined:-
Take a moment to read through the following document, it discusses the various redundancy modes of operation and failover duration:-
Command to initate a failover:-
'redundancy force-switchover' or
'reset
Hope this helps..
Allan.
