AP 1131AG
Answered Question
Oct 21st, 2008
Hi all, is it possible to disable the light on an AP 1131 AG by software or if not by hardware^
Thanks.
Ben
Correct Answer by Rob Huffman about 8 years 6 months ago
Hi Ben,
Give this a try;
config ap led-state
To enable or disable the LED-State for an access point, use the config ap led-state command.
config ap led-state {enable | disable} {Cisco_AP | all}
Syntax Description
config
Display configurations.
ap
Advanced parameters.
led-state
Enable or disable the LED-State for an access point.
{enable | disable}
Enable or disable the access point's LED-State.
{Cisco_AP | all}
Name of a Cisco lightweight access point or all to specify all access points.
http://www.cisco.com/en/US/docs/wireless/controller/4.1/command/reference/clic1.html#wp2384867
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Tue, 10/21/2008 - 06:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ben,
Give this a try;
config ap led-state
Syntax Description
config
ap
led-state
{enable | disable}
{Cisco_AP | all}
Hope this helps!
Rob
bseguin06 Tue, 10/21/2008 - 07:58
Hi Rob,
Thanks a lot for your help.
You point me in the right direction.
The exact command for this model is :
config led display off
Thanks again and have a good day.
Ben
Rob Huffman Tue, 10/21/2008 - 08:12
  • Hall of Fame,
    Founding Member
Good stuff Ben! Thanks for posting back with your actual results (very helpful my friend :)
Cheers!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
