TCP checksum offloads - slow internet response times
Oct 21st, 2008
Has anyone seen an issue were a client was having internet slowness issues (with using a proxy server) and upon investigating a packet sniff revealed bad checksums and the possible cause is "TCP checksum offload"? The bad checksums are only sourced from the client side.
Overall Rating: 3 (1 ratings)
mbroberson1 Tue, 10/21/2008 - 10:13
Can is cause (being turned on or off) issues related to slowness?
mbroberson1 Tue, 10/21/2008 - 10:28
What if you had say a Microsoft ISA server and the internal nic had this enabled, but the external nic had it disabled or vice versa. Could this lead to an issue?
