CM6.1 Find Devices to Add to Route Group
Answered Question
Oct 21st, 2008
Hi!
I'm trying to create a new route group but the device I want to add as a member does not appear when I do the "Find". It's a trunk that is already configured under "Device>Trunk". Do you have any idea that justifies this behavior?
Best Regards,
Ana
Correct Answer by Chris Deren about 8 years 9 months ago
ensure the trunk is not assigned directly to any route patterns.
Chris
Overall Rating: 5 (1 ratings)
iptuser55 Tue, 10/21/2008 - 08:44
  • Silver, 250 points or more
I`ve seen this serveral times- does not always makes sense as it is not always true either but it seems to be if you have assigned the trunk to a RL, RG then you can only see it from the RL, RG
Correct Answer
Chris Deren Tue, 10/21/2008 - 11:30
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Chris
abartolomeu Tue, 10/28/2008 - 08:54
Hi!
The problem was exactly that it was already assigned to a route pattern.
It is solved!
Ana
