Problem with a Cisco 857W config
I'm having real trouble getting a Cisco 857W to access the internet. I've config'd these boxes in the past - admittedly to a Private VPN - and they've worked a treat. This one is proving very troublesome. Here's my config (adapted from a 'working' 857W)
Current configuration : 2422 bytes
version 12.4
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname xxx
boot-start-marker
boot-end-marker
enable secret xxx
no aaa new-model
dot11 ssid jimsaca01
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii xxx
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.215.21.1 10.215.21.50
ip dhcp pool acas
import all
network 10.215.21.0 255.255.255.0
default-router 10.215.21.1
lease 0 23 59
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip domain lookup
username mxuser password xxx
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
beacon period 200
no dot11 extension aironet
encryption mode ciphers tkip
ssid jimsaca01
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description ****local interface****
no ip address
bridge-group 1
interface Dialer0
description ****Out to BT Internet****
ip address negotiated
ip virtual-reassembly
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname mxtsuk/jlennon^acas.org.uk
ppp chap password xxx
interface BVI1
description $ES_LAN$
ip address 10.215.21.1 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
access-list 100 permit ip 10.215.21.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password xxx
login
scheduler max-task-time 5000
end
I've debugged ppp authentication and negotiation and this looks fine (the router is picking up it's public IP address from our ISP) - see attached
The interfaces also look OK (see attached)
I am also able to connect to the wireless card.
Any help would be much appreciated.
Best wishes
Miles
jeff.kish Tue, 10/21/2008 - 07:18
This would probably be best posted in one of the routing/switching forums. This is the wireless forum, and the people here tend to specialize in wireless connectivity. You might have better luck posting over there.
As for your problem, what do you get when you do a traceroute from your router to the Internet? Can you get past your ISP's router? Can you do this with clients hanging off the router?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
