Default PIN
Oct 21st, 2008
if you add a user in CM version 6 but leave the password and PIN field blank what default value gets assigned can you edit this?
Tommer Catlin Tue, 10/21/2008 - 08:04
I dont think it lets you keep it blank if add a user. If you want to use the PIN/Password you have to manually (or bulk) the user to the CCM standard user group to use the CCMuser page.
