Problem with a Cisco 857W config
(I originally posted this over in the wireless section but was advised to pop it over here)
I'm having real trouble getting a Cisco 857W to access the internet. I've config'd these boxes in the past - admittedly to a Private VPN - and they've worked a treat. This one is proving very troublesome. Here's my config (adapted from a 'working' 857W)
Current configuration : 2422 bytes
version 12.4
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname mx_jlennon
boot-start-marker
boot-end-marker
enable secret 5 $1$nhGM$/ONk1CcM2Mh.N1yEh67OB1
no aaa new-model
dot11 ssid jimsaca01
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 030E5206151F2D4D4D0C18111F1D0609
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.215.21.1 10.215.21.50
ip dhcp pool acas
import all
network 10.215.21.0 255.255.255.0
default-router 10.215.21.1
lease 0 23 59
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip domain lookup
username mxuser password 7 1043110C161200
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
beacon period 200
no dot11 extension aironet
encryption mode ciphers tkip
ssid jimsaca01
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description ****local interface****
no ip address
bridge-group 1
interface Dialer0
description ****Out to BT Internet****
ip address negotiated
ip virtual-reassembly
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname mxtsuk/jlennon^acas.org.uk
ppp chap password 7 12090442471C03162E
interface BVI1
description $ES_LAN$
ip address 10.215.21.1 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
access-list 100 permit ip 10.215.21.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 141B071D0D003F282F
login
scheduler max-task-time 5000
end
I've debugged ppp authentication and negotiation and this looks fine (the router is picking up it's public IP address from our ISP) - see attached
The interfaces also look OK (see attached)
I am also able to connect to the wireless card.
Any help would be much appreciated.
Best wishes
Miles
Overall Rating: 5 (1 ratings)
Jon Marshall Tue, 10/21/2008 - 13:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Miles
Have to admit it's been a long time since i did anything with these routers so i could be off base but you have a DHCP pool of 10.215.21.0 255.255.255.0. These addresses are not routable on the Internet so you need to NAT them to a public IP address but i can't see any NAT commands in your configuration.
Jon
