Edison Ortiz Tue, 10/21/2008 - 10:12
  • Hall of Fame,
    Founding Member
You need to copy the IOS image in the standy Supervisor as well.
HTH,
__
Edison.
Juan Ignacio Giraldo Tue, 10/21/2008 - 15:32
But the router was operating normally(since 2 months ago), it was not turned off, the IOS has not been changed, nor the register....what can produce such event log ?
Edison Ortiz Wed, 10/22/2008 - 05:22
  • Hall of Fame,
    Founding Member
Perhaps someone deleted the file by accident.
Verify the file is there, if it isn't - please copy it from the active Supervisor to the standby.
HTH,
__
Edison.
Juan Ignacio Giraldo Wed, 10/22/2008 - 06:11
Hello Edison. Thanks for your responses.
Could you please give me a procedure to follow (including commands) so i can verify if the file exists or not and if not, how to copy ?
I'm just a begginer in my job and my boss asked me to perform this taks (to find out how to do that).
Thanks a lot
Juan Ignacio Giraldo Wed, 10/22/2008 - 14:06
Eduard. Hi again.
This is the equipment's sh ver print:
System image file is "bootdisk:c7600s72033-advipservicesk9-mz.122-33.SRB2.bin"
cisco CISCO7606 (R7000) processor (revision 1.0) with 458720K/65536K bytes of me mory.
Processor board ID FOX084000FG
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
23 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
I don't really understand how can i copy files from one memory to other.
How can i know how many slots for memory my router has ?
Edison Ortiz Fri, 10/24/2008 - 17:08
  • Hall of Fame,
    Founding Member
My name is Edison.
Please post the output from typing dir /all
__
Edison.
