WCS not showing AP type or antenna choices
Oct 21st, 2008
When I look at the config for some of my AP's they are showing under the Inventory Information AP Type Unknown. Also, when I go the radio interface for b/g and try to change the external antenna from Other to the 5959 antenna, there is no antenna's listed at all.
I looked at other AP's that are working and they show AP Type as LWAPP and have all the antenna choices listed as well.
The WLC version is 4.2.112 and the WCS version is 4.2.81.
I found this problem after changing some of the AP's to manually set the channel assignment. I then went to look at the heat map for all the AP's in one building and nothing shows up, just the AP's with no color heat map. I did reset the AP's with no change.
Thanx, Seth
bwilmoth Wed, 10/29/2008 - 12:48
  • Silver, 250 points or more
Heat maps are not generated in WCS 4.0 version. The workaround and conditions for This similar issue has been given in the bug ID “CSCse83815”.
srosenthal Wed, 10/29/2008 - 13:17
If they are not generated, then how am I getting them for most of my network?
Seth
srosenthal Wed, 11/05/2008 - 12:06
Well, it is now working. The problem believe it or not was the sup module in the core switch was failing. Once that was replaced, the heat maps worked correctly.
ericgarnel Sun, 11/09/2008 - 10:05
  • Gold, 750 points or more
Seth,
What error messages and/or debug messages were you seeing? I think I may have the same issue
Eric
srosenthal Mon, 11/10/2008 - 06:56
Was not seeing any error messages. I was just not able to get the heat map to generate. Also, I could not choose the correct antenna that was connected to the AP because the AP type was showing up wrong.
ericgarnel Fri, 11/14/2008 - 05:44
Seth,
Have you found a fix yet? My issue turned out to be someone playing with the ether-channel load-balancing type on the 6500s..
srosenthal Fri, 11/14/2008 - 05:47
Yes, we had to replace the bad sup module in the 6509. It had been causing problems for a while, this was just another problem caused by the bad sup.
Seth
Trending Topics - Security & Network
