htarra Wed, 10/29/2008 - 12:31
You can use the following configuration:
probe tcp MS-SQL
description TO-RBSQL1
ip address 10.15.160.3
port 1433
interval 2
faildetect 2
passdetect interval 2
passdetect count 2
rserver host RBWEB1
ip address 10.15.177.11
rserver host RBWEB3
ip address 10.15.177.13
inservice
serverfarm host RBWEB
description TO-VLAN-177-RBWEB-SERVERS
predictor leastconns
probe WWW-RISKBROWSER
probe PING
rserver RBWEB1
rserver RBWEB3
inservice
And also you can use the command sh probe MS-SQL, to know probe association probed-address probes health. Sure that the server respond or responded with a RST.
dwc Wed, 10/29/2008 - 12:39
Hi HTarra,
Thank you for your response. My customer wants to know that the actual database is responding to queries. The socket listener proble you suggest will tell us if the SQL port is 'up', but they want to know if the database is 'up'.
This is why I asked if anyone had written a TCL script. Unless Cisco creates a SQL probe, we will have to write it ourselves.
Dave
