10-21-2008 12:45 PM
Can we configure CSS 11503 in Active/Active mode, means can multiple context would be configured?
Thanks & Regards,
Shahzad.
Solved! Go to Solution.
10-21-2008 03:49 PM
Here you go
Assumptions:
VIP 10.10.10.100 is Master on the CSS 2 and backup on the CSS1
VIP 10.10.10.101 is Master on the CSS1 and backup on the CSS1
Vlan 10 is the Server Vlan (Redundant Interfaces here)
Vlan 20 is the Client vlan (Redundant Vips here)
Services for VIP 10.10.10.100 (real server) have default gateway pointing to redundant interface 172.20.40.253
Services for VIP 10.10.10.101 (real server) have default gateway pointing to redundant interface 172.20.40.254
CSS #1
circuit VLAN10
ip address 172.20.40.1 255.255.255.0
ip virtual-router 1 priority 101 preempt
ip virtual-router 2
ip-redundant-interface 1 172.20.40.253
ip-redundant-interface 2 172.20.40.254
Circuit VLAN20
ip address 10.10.10.1 255.255.255.0
ip virtual-router 3 priority 101 preempt
ip virtual-router 4
ip redundant-vip 3 10.10.10.101
ip redundant-vip 4 10.10.10.100
CSS #2
circuit VLAN10
ip address 172.20.40.2 255.255.255.0
ip virtual-router 1
ip virtual-router 2 priority 101 preempt
Circuit VLAN20
ip address 10.10.10.2 255.255.255.0
ip virtual-router 3
ip virtual-router 4 priority 101 preempt
More details at
Syed Iftekhar Ahmed
10-21-2008 01:20 PM
There are no contexts in CSS but active/active can be configured on VIP basis.
Meaning One CSS willl be active for APP1-VIP and other CSS would be active for APP2-VIP.
This will give you an example
Syed Iftekhar Ahmed
10-21-2008 02:56 PM
Thanks boss; can you have the similar example where CSS is configured in Bridge Mode.
Shahzad.
10-21-2008 03:19 PM
Shahzad
VIP/Interface redundancy is not recommended for bridge mode deployments. CSS in inline bridge mode with vip based redundancy is vulnerable to bridging loops.
With inline bridging BOX-to-Box redundancy (Active/standby) is the recommended method.
Syed Iftekhar Ahmed
10-21-2008 03:25 PM
Dear Iftikhar,
Since I am in the designing phase and there is no specific customer requirement to place CSS in Bridge or Routed Mode or One-Arm Mode. I can plan in Routed Mode, to achieve Active/Active which is the requirement of customer. Do you have an example configuring inline routed mode to CSS?
Thanks and Regards,
Shahzad.
10-21-2008 03:49 PM
Here you go
Assumptions:
CSS #1
circuit VLAN10
ip virtual-router 2
Circuit VLAN20
ip virtual-router 4
CSS #2
circuit VLAN10
ip virtual-router 1
Circuit VLAN20
ip virtual-router 3
More details at
Syed Iftekhar Ahmed
