10-21-2008 12:54 PM - edited 03-06-2019 02:04 AM
can you connect one end of the interface as Gi 0/0 and the other side as Fast ether
Solved! Go to Solution.
10-21-2008 01:15 PM
As long as the gigagbit interface supports 10/100/1000 speeds then yes you connect the two ends and run them at 100 full duplex.
Jon
10-21-2008 01:15 PM
Jon
10-21-2008 01:18 PM
I guess I can ,,, !!!
