NAC Appliance and LDAP Lookup
Answered Question
I have two CAM in HA and two CAS in HA.
I configure the LDAP Lookup for create rule to role allocation.
In this configuration are only one windows server to make find the user properties.
There are one problem when this Windows servers is down. There are any configuration to mitigation when the server is not there.
Thank you all.
Correct Answer by Daniel Laden about 8 years 5 months ago
The LDAP lookup server configs state it uses the LDAP Authentication Provider. The LDAP Authentication Provider says you can have multiple entries in the single field
LDAP
http://www.cisco.com/en/US/docs/security/nac/appliance/configuration_guide/413/cam/m_auth.html#wp1158614
You can add redundancy for LDAP Authentication servers by entering multiple LDAP URLs in the Server URL field separated by a space, for example:
ldap://ldap1.abc.com ldap://ldap2.abc.com ldap://ldap3.abc.com
Overall Rating: 5 (1 ratings)
flitcraft33 Wed, 10/29/2008 - 15:16
I believe that in version 4.5.0 you can add more than one LDAP look up server. Of course to get to 4.5.0 you must be running on the "appliance" hardware according to Cisco.
Correct Answer
Daniel Laden Sat, 11/08/2008 - 10:29
  • Cisco Employee,
LDAP
