7965 on Callmanager 4.2(3)
Oct 21st, 2008
How do I create the 7945/7965 devices on CM4.2? I installed the firware on the published and all files are on the tftp folder but the phone type is not showing in the GUI.
sebastiandm Tue, 10/21/2008 - 14:34
You will need to install the appropriate device packs for your version of CUCM. They can be downloaded from the software centre.
rcrumm_2 Tue, 10/21/2008 - 14:54
I just applied a device pack to our cluster last Friday bvecause we are going to start buying the 7945's, but the 7965 were included in the upgrade as well.
You can download the devive pack and install off hours.
Randall
