Cannot dial : area code getting stripped off when dialing out
Oct 21st, 2008
  • Silver, 250 points or more
I am seeing following debugs on gateway router . Why i am seeing in logs "5606751" when i am dialing 830560751? How will i know which DP it is actually using to dial out from debugs?
Oct 21 18:11:34: ISDN Se1/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x6CC6
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x2181, '50100'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '5606751'
Oct 21 18:11:34: //392762/80546BB06672/H323/cch323_do_call_proceeding: gw_id=1
Oct 21 18:11:34: //392762/80546BB06672/H323/cch323_do_call_proceeding: set_mode NOT called yet...saved deferred CALL_PROC
Oct 21 18:11:34: //392762/80546BB06672/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_LISTEN_REQ_EVENT
Oct 21 18:11:34: //392762/80546BB06672/H323/cch323_h245_connection_sm: state=0, event=0, ccb=64DB31DC, listen state=0
Oct 21 18:11:34: //392762/80546BB06672/H323/cch323_h245_connection_sm: H245_LISTEN: Received event H245_LISTEN_REQ_EVENT while at H245_NONE state
Oct 21 18:11:34: //392762/80546BB06672/H323/cch323_h245_set_new_state: Changing from H245_NONE state to H245_WAITING state
Oct 21 18:11:34: //392762/80546BB06672/H323/cch323_process_set_mode: Setting inbound leg mode flags to 0x10F, flow-mode to FLOW_THROUGH
Oct 21 18:11:34: //392762/80546BB06672/H323/cch323_process_set_mode: Sending deferred CALL_PROC
Thanks in advance.
Overall Rating: 5 (2 ratings)
Chris Deren Tue, 10/21/2008 - 15:40
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Run "debug voice dialpeer"
Chris
Jaime Valencia Tue, 10/21/2008 - 18:48
  • Cisco Employee,
  • Hall of Fame,
    2011
most probably you have your dial-peer with the 1st digits as exact match and they got stripped. that's working as designed, you need to configure how many digits you want to send if not doing it with the digits on the destination-pattern.
i'd recommend you to go thru the dial-peer configuration guides to get some more insight but let's put it this way
if i have
dial-peer voice 1 pots
destination pattern 123.......
and i dial 1234567890 i will only send NON-EXACT matches = 4567890
java
if this helps, please rate
