CRC errors on fibre link
scu_comms
Setting up a link 14KM using SFP-ZX and 10db attenuators on the receive legs. Am getting CRC errors on one end only.Swapped SFP's no difference...any ideas??
Tom Randstrom
You didn't mention what platform you are using. Have you checked to see if there is a Field Notice for this issue on the hardware?
Does the hardware support provisioning of CRC size, as there might be a mismatch? Do you see any other errors? Have you tried to swap the fibers to see if the error follows the fiber link?
Just some thoughts.
Have you tried cleaning the connectors?
