what does Qty of "SCUE language options" mean?
Oct 21st, 2008
When using Dynamic configuration tools to config NME-CUE, it has options for "SCUE language options" and has Qty options beside this, so what does it mean? Plz explain, thank you very much!
slongewa Wed, 10/22/2008 - 04:54
You can have multiple languages for Unity Express. i.e. English and Spanish, or English and French or something like that. If you're in a single language country, you would just pick 1, and then set it to whatever your native language would be.
HTH,
Steve
huydien3384 Wed, 10/22/2008 - 18:39
Yes, just pick 1. If you choose SCUE 3.0, you cannot adjust the Qty, but if you choose SCUE 3.2, it allows you to change the Qty of Language options, sound like a mistake from Cisco. Thank you
