Detailed CED Input Report, IPCC Enterprise
Oct 21st, 2008
  • Silver, 250 points or more
Hi, I have received a request to generate a complete CED input report at IVR. The Termination_Call_Detail table has a column 'CED' which records the last pressed CED by customer, but how can I get the full CED history?
Let me clear the issue, if a customer press '1>6>2' before he tear down the call, 'CED' column has the record of '2' only. But I want to get the record '1,6,2'.
Any help will be highly appreciated.
I have CVP 3.1, ICM 7.2(2) in my setup, any idea?
Overall Rating: 4 (1 ratings)
Chris Deren Wed, 10/22/2008 - 06:11
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Your best option would be to script the ICM scripts with appropriate call types for each menu option, which would allow you to look at Webview and see how the calls were distributed.
Otherwise you're looking into developing some custome report from the historical tables based on the CED field.
HTH,
Chris
Md. Mijanur Rahman Wed, 10/22/2008 - 20:17
Hi, Thanks.
Yes i'm looking for some custom report from CED field at any table.
Yes i have your idea, define call types for each of the menu/sub-menu and I already have it, the best i can get is the utilization history of menus (i.e. call types).
But customer needs a report containing the CLI of customer with his CED history.
One more thing, can I do anything at CVP?
sandeepkaran Thu, 10/23/2008 - 01:54
I guess from the same table combination of following fields will give you the CED
RouterCallKeyDay, RouterCallKey, CED , CLI , CALLTypeID.
best regards
Sandeep
Md. Mijanur Rahman Thu, 10/23/2008 - 03:12
Yes, i can get the CED but that's the last pressed one. How can I get full CED history a customer pressed?
Is the menu application built with microapps or Cisco CVP Studio?
If it's being done with microapps you could concatenate the result at each step into a PV or ECC variable.
If it's being done with Cisco CVP VXML (ex Audium) then you can easily track the menu selection through the tree and pass it up to ICM in a FromExtVXML[] element and save it (again) in a PV or an ECC variable.
Geoff
Md. Mijanur Rahman Thu, 10/23/2008 - 10:24
I'm using microapp 'GD' or 'CED Node' at script to collect CED at script.
Yes, I can concatenate the collected CEDs together until call is finished, but it will need lots of changes at all current running scripts, need to put 'set variable' node before each 'GD/CED' node, it's a huge task to complete you know. Though it's choice, but who doesn't want to avoid this?
My CVPs don't have VXML server, VXML is running on the gateways, so #2 isn't my choice.
Can I use my CVPs or gateways with/without little changing at ICM scripts?
